3D Printers and Software: Flashforge Creator Pro with Flashprint Creator Pro is one of the earliest printers that I bought and it worked right out of the box with the software and I didn't have to understand any of the settings to make it work since I used the default profiles of the software which were perfect. The dual nozzle of this printer can be useful for specific applications and I usually print with ABS only on this printer as it has an enclosure to keep the heat in. It has a direct drive extruder. I still use the Flashprint software to modify the STL files, cut pieces or repair files before I save them as a new STL and upload them on Simplify3D for other printers.
Winbo SuperHelper 155L (stock) with Simplify3D or Cura
This is my smaller printer (yellow one in the back) that's just easier to carry around with its handle on top weighing a few kilograms. I use this for smaller prints like rings, small test prints and for showcasing 3D printers at local events to people.
Tevo Tornado (stock) with Simplify3D
This is one of my favorite printers which is why I have 2 of them. With a 300x300x400mm build volume its bigger than the previous 2 printers and so I usually use it for bigger prints. I think this printer handles the flexible filaments perfectly and since it has a glass surface I can put glue on the surface in case I want the filament to stick better to the bed. I use TPU filament ONLY on this printer. The control box can be seen in the bottom right corner of the picture.
Tevo Nereus (stock) with Simplify3D
This is also an excellent printer and space saving as all the electronics are underneath the headbed (pictured in the centre with the orange housing) so there is no separate box for control like with the Tevo Tornado or Creality CR-10S5. With a build volume of 320x320x400mm this one worked out of the box for me too and has additional functionality of filament detection like CR-10S5, which is lacking in the Tornado. Though the heatbed surface is not glass, its still pretty smooth and easily cleaned with alcohol. Its the only one of my printers that has WiFi connectivity capability built in though I've never fully used that feature.
SparkMaker Original (stock) with SparkStudio or Chitubox
I use this SLA printer (kept in the protective thermocol case that it came in pictured in the back) for really small parts that need very high detail, like figurines. Though the cleanup time is a lot more compared to FDM printers with UV curing and the proper handling and washing of the resin but the results are worth it. I only use it for high-detail parts smaller than 50mm though and do not always utilize its full print volume.
Creality CR-10 S5 (with 0.8mm nozzle) with Simplify3D
It came with the default 0.4mm nozzle but after a few prints I shifted it to 0.8mm for faster prints on the 500x500x500mm giant printer (pictured on the extreme right). I usually use it for really big prints (The whole of Do3D Ironman MK50 suit's back fits easily on the printer). It also has a filament sensor. Printing at 0.4 or 0.6mm layer height can have some problems with nooks between layers but that's easily fixable post printing. I print things at larger layer heights with this printer that I don't intend to sand later on after using a filler. I also use my Thibra Skulpt flexible filament on this with ease. which is great for things where you need a little flexibility like the joints of knees, or elbows... or my favorite, shoes of the Ironman suit!
Flashforge Thor500 (stock) with Simplify3D
This is my latest 500x500x500mm printer and has the default 0.4mm nozzle (pictured on the extreme left). I've only printed a few things on it so far but in terms of performance right-out-of-the-box it has not disappointed. It has a flexible magnetic build surface which helps remove the prints easily. It has a filament sensor and comes with a pretty stable spool holder that goes on top of the frame. Like the Creator Pro it has a direct drive extruder instead of the bowden extruder mechanism in the other printers above. The biggest advantage it has over the CR-10S5 is that the electronics are fitted underneath the bed so no side controller box which can be an issue when trying to find a place for printers of this size.
My Simplify3D profiles for different printers and Filaments (PLA by default) are here for perusal and editing as you see fit: https://drive.google.com/drive/folders/1OS6hQ1zJ1d4XiH_iW1r2wmnTn6g-yTqU
I bought all my printers from RoboRium.com
My projects can be seen on my instgram.com/BeardedMaker
Filaments: PLA, PETG, and sometimes ABS for solid parts
TPU and Thibra Skulpt for parts that need a little more flexibility
Resin: Sparkmaker
Common Tools:
Gluesticks OR Glue+Water mixture for making things stick to the headbed if needed
Masking tape to put on some heatbed surfaces for protection before butting glue on them
Spatulas for lifting prints off heatbed when needed or a blunt spatula for cleaning a sticky glass surface with alcohol
Tweezers to clean up extra filament that hangs from nozzles before the print starts or when the hot end requires cleanup
Ethanol for cleaning heatbeds and washing away unused resin from SLA prints.
Working with multiple printers can sometimes feel overwhelming, especially when managing complex projects. Simplify3D makes it easier by streamlining the process, allowing better control over each printer’s settings and improving overall efficiency. Whether you’re printing small parts or large models, this software helps keep everything organized and running smoothly. When it comes to keeping your workspace comfortable and clean, Upholstery Cleaning plays an important role in maintaining a fresh and inviting environment. A clean space supports focus and creativity, which is essential when handling multiple printers and detailed printing tasks. Balancing technology and cleanliness can make a big difference in productivity and satisfaction.
Globaldev Group provides cutting-edge services in terms of software engineering and team extension to help our global partners address the most complex digital transformation needs and untangle the most ambitious software challenges.
We deliver the exceptional so your project is in good hands.
https://www.globaldev.tech/
Set up individual printer profiles for each of your 3D printers in Simplify3D. This includes specifying the printer's build volume, nozzle diameter, bed shape, and other relevant settings. Go to instant casino withdrawal games "Machine" to add and configure your printer profiles.
Is it better to outsource a company's call center activity or keep it in house?
Why don't you take advantage of the various opportunities that different studios and agencies now provide, such as bubble app development. This is a great option for busy people like you to leave project and developer management to a dedicated project manager. In addition, there are no hirings and contracts. As long as you need services, just pay for a subscription.
I need quality software for business, but I don't have time to look for developers and the whole development process.
I agree that convenient software is a huge advantage, and it's essential to use secure software to avoid having any problems in the future. When I needed to develop software for my project, I checked many articles like https://sloboda-studio.com/blog/offshore-development-models that helped me make the best decision, and I'm more than satisfied with the final result.
I would like to mention the fact that currently all programs must be safe because they protect our computer. In addition, I also want to mention the fact that I recently found this magento 2 nginx install development services where there is information about the right tools and services for developing a business. This allowed me to better understand the safety of my own equipment and improve the process of its operation.
A 3D printer is a very good thing, no matter what you do. If you need it for a hobby, that's fine, if it's for work, then it's even better. Recently, friends gave me one, but it turned out to be defective and I had to go through many procedures to change the product. The sediment from all this remained unpleasant, but a week ago Ajax systems was brought to me and everything was fine there, I'm glad about that, so my mood is much better after the precedent with the printer. Nevertheless, I will print figures from video games and rejoice.
