Do3D Updates
Public·59 members
Darksaber update with different length of blades and separated hilt | 3D printable model print file STL Do3D
2 different sizes of blades: as you can see in some of the movie / film screenshots, the blade keeps extending out further and is shown much longer in many scenes. Sometimes the blade measures 3 times longer than the hilt but it would also measures shorter in some scenes. As a result, the longer blade is provided as optional for those who believe the blade should be longer. Please check the film screenshots posted below.
The new version also features a new hilt separated into 5 pieces that snaps / fits on to each other.
We recommend you using a resin printer. If you are using an FDM printer, some sanding may be required at the connecting areas of these pieces.
🙏 Do3D gives free life time updates to all valid purchases made directly on do3d.com. Thank you very much for your support!
